A couple pre-road trip questions - oil filter and HVAC...
Guys-
Taking the car for a weekend spin up in the mountains this coming weekend - going to Ouray - twisties, amazing scenery....
So a couple questions....
Changing the oil - When I bought the car it had a bigger oil filter on it - bigger than the one that is spec'd - suggested by the shop in AZ. I have since changed it to stock at last oil change but want to go back to a bigger filter - I figure more filter is better, no? - anybody have suggestions which Mahle filter to get. I don't understand the differences between all the numbers frankly....
Next - HVAC - fun fun. Ok my system is charged with R12. I get nice cold air out of driver side and feet. Passenger side is warmer. Center vents you can tell it's blended with some warm air - the HVAC servos (2 and 4) are in the proper position for cold setting. Is there a hose that I should check to see if it's ripped and allowing warm in????
Thanks much
Thanks much
Guys-
Thanks much
Thanks much
Change the a/c filter
