Turbo with KW V3s
Anyone got KW V3s fitted on their Turbo? I was wondering how difficult it is to change the settings as well as any other reflections on how performance was affected??
I had them on my 964 C2 and they transformed the handling of the car and yet had
Good comfort . If its mainly road use , you cant go wrong . If its more track work then the
Clubsports are a minimum . Great quality too . I know a couple of guys in the UK have them on
Their turbos , but they dont go to the track . Dont the latest versions have remote adjustment ?
Hope that helps a bit .
Thanks Jonny.
Mainly road use but also want performance on track so according to this...
http://www.kw-suspensions.co.uk/imag...010-xl-img.jpg
...it looks like V3 fits the bill nicely covering a broad range. CS I think would be a bit uncompromising for road (unless anyone else can advise otherwise?). What I'm concerned about is whether or not it is practical in a Turbo to access the adjustments (i.e. can I change settings in a half an hour without dismantling the car), otherwise I should just go for V1 or something else fixed.
These guys you know, can they advise on the accessibility for changing settings on a 964 Turbo? Do the wheels or IC need to come off to adjust the rears?
I spoke to KW and they have no plans for a DDC ECU 964 Turbo version, which would have been perfect. Adjustments at the touch of an iPhone!
