Suspension Arms
Dear All
Have been away for awhile busy with traveling for work... Hope everyone's had a good start to the year!!
I was just wondering if there are alternatives for suspension arms for the 3.3T? I am looking to replace the arms and bushes (as they are 20 yrs old) and have been advised to go with the stock bushes (as I will not be tracking the 3.3T)..
I was reading Total 911 and noted that Regal in the UK has replacement suspension arms with spherical bushes which allow for more adjustment - camber etc...
Are there any similar for the 964T? Had a look around the site but couldn't find anything from the searches.
I thought since I will be replacing the arms, that I might as well see if there are any options to consider. Am going with Bilstiens and H&R Red springs as well.
Any thoughts would be most appreciated..
When searching for parts, start with the 964 board as those cars share 80% of their parts with Turbos.
There's no need to replace the arms because the bushings are bad. I've never, ever heard of anyone experiencing a fatigue failure of an aluminum suspension arm. The use of aluminum suspension arms is widespread in the industry and have been verified as safe for long term service, so there is no need to replace them if not damaged.
For aftermarket bushings there's Elephant Racing, Walrod and Powerflex. All have their benefits and drawbacks, including price.
Thanks Paul...
Will double check with the mechanic.. I believe its just the bushes that he wants replaced...
Just did an order on Pelican parts for some of the rubber trims... Lots more stuff to get... Yikes!!
Are you replacing just because of age? I have not found age to be an issue both my C2 and turbo bushings are still in perfect condition. Even with track miles on the C2 so far so good. Try the crowbar method of checking to see if they are still in good working order. If you are going with H&R and Bilsteins stick with factory no need for anything else.
THanks Tony
Ues, primarily as they are 20 years old.. will have the mechanic double check to see how much give they have... I was just speaking to him about it earlier and he was a little worried that if he was to remove the original bushes from the arms, that they new ones may not go back in as snugly..
Thanks for the advice..
964 turbo owners have been known to retrofit narrow body rear swing arms to allow the use
of a wider wheel as 10.5 -11.0 is about the limit with originals...Bert
Ues, primarily as they are 20 years old.. will have the mechanic double check to see how much give they have... I was just speaking to him about it earlier and he was a little worried that if he was to remove the original bushes from the arms, that they new ones may not go back in as snugly...
Maybe you should find an more knowledgeable mechanic.
I'm running 10-3/4's which puts the inside wheel lip at 5-6 mm from the trailing arm. I even went as far as to remove the casting parting line to gain even more clearance. I run the normal 1 degree negative camber. That extra 1/4 inch to get to 11 is to the outside of the wheel, hence the need for extreme camber.
Spartan has the set up of which you speak on his 964T.
Thanks for that Paul ,yes I'm certainly not recommending trying to run 11'' rears without some extreme camber adjustments even at that I won't be trying it.
I have a set of narrow body arms myself just haven't begun the retrofit of the drivetrain ,the rear
suspension arms can wait..
Maybe what the OP was looking for is a monoball spherical bearing setup and mistakenly mentioned
swing arm replacement?
These can be found at a few places Pelican I believe has an assortment of bearing/metal bushing
replacements..Bert
replacements..Bert
There appears to be 3 sources for front end bushings (Elephant Racing, Walrod and Powerflex) but I've only seen Powerflex bushings for the rear arms. Spring plates are, like you said, spherical bearings or stock ($$$). I think it takes $2500 to do it all.
Basic Sponsor
Hsianers - Which direction did you end up going with the bushings?
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
Thanks All for the comments..
Have not gotten round to ordering the bushes as yet as have been traveling every weekend since Christmas...!!
Was just looking at the stock standard bushes for both front and rears but will have the mechanic put a crowbar to them to see how much give there is...
The rebuild is taking way longer than originally anticipated.. but I suppose thats the norm....
