964 Turbo Forum 1989-1994
It Runs!
Old 07-19-2013, 11:08 PM
mapolus
mapolus's Avatar
Default It Runs!
Well, just finished a service on my new-to-me 964 Turbo. And it seems to run okay and I didn't have any leftover parts!!
My only recommendation is to definitely buy the Brake Bleeder from Pelican Parts (PEL-0109). That was the only easy part of the 3-day ordeal. Oh yeah, buy lots of paper towels.
Old 07-22-2013, 04:02 PM
PelicanParts.com
Basic Sponsor
PelicanParts.com's Avatar
Matt- pretty turbo you have there! What did you cover with this service; just curious?
Isn't the brake bleeder a great product! Ease of use is such a plus!
Motive Power Bleeders
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 07-22-2013, 05:50 PM
Metal Guru
Metal Guru's Avatar
The Motive power bleeder is a nice tool. Wish I had the one with the swivel to, though
Old 07-23-2013, 12:16 AM
mapolus
mapolus's Avatar
Okay, so the game plan was to create a DIY listing...but once I got in there, I realized I needed more help from you guys than I could really offer in return. With that said, I can at least provide my sequence of events:
Services: Oil Change / Transmission Fluid Change / Air Filter / Valve Adjustment / Valve Cover Gaskets / Spark Plugs / Power Steering Fluid Change / Brake Fluid Flush
References:
1. Auftragsnummer 964 (Adrian Streather)
2. Type 964: Technical Data Without Guesswork (Bentley Publishers)
3. 101 Projects for Your Porsche 911 (Wayne Dempsey)
Procedure I used:
1. Drive car until oil thermostat opens (temp gauge at 9 o'clock)
2. Break loose lug nuts on all four wheels
3. Jack-up car (101 Projects - Page 17)
4. Drain Oil (Streather – Page 81)
a. There are three drain ports for 964 Turbos
i. Oil Cooler Thermostat – in front of Right Rear Wheel
ii. Engine Crankcase
iii. Turbo Oil Collection Container (official name?)
b. Oil Filter removal: I used the 3-prong oil filter wrench at Sears (Product #02820523000)
c. The oil comes out fast!!! Like Niagara Falls fast!
5. Drain Transmission Fluid (Rennlist 964 DIY by elbeee964 posted on 02MAY09)
6. Remove Intercooler (Streather – Page 467)
a. There were many more hoses/wires than I expected. Ensure you label them as you go!
7. Remove Air Filter Housing
a. It was easiest to remove the A/C compressor first
8. Change Air Filter
9. Remove enough hoses/wires to reach upper valve covers (there’s a lot!)
10. Remove Upper and Lower Valve Covers
11. Remove Spark Plugs
12. Adjust Valves as necessary (Streather – Page 425)
a. It was necessary to remove the A/C Compressor in order to remove the Air Filter Housing, so using a wrench to turn the crank was not possible. So, I gently rotated the fan itself with my fingers (always clockwise!)
b. You should be able to rock the intake and exhaust valves slightly when that cylinder is at TDC.
c. Getting the Feeler Gauge into the gap is tough on the Intake valves. The exhaust valves on the right side were the easiest (Cylinders 4-6)…try those first.
13. Install new spark plugs / spark plug wires / distributor cap / rotor
14. Install new valve cover gaskets and valve covers
15. Change Fuel Filter (Streather – Page 84)
16. Reassemble everything else (the labeling is key!!)
17. Complete Oil Change procedure (Streather – Page 81)
18. Complete Transmission Fluid Change procedure (Rennlist 964 DIY by elbeee964 posted on 02MAY09)
a. I’ve tried the gravity method to refill the transmission on other cars, but I found it much easier to use a cheap pump from Wal-Mart
19. Flush Brake Fluid (Streather – Page 265)
a. There are 2 bleed valves at each corner (inner and outer)…bleed both.
20. Power Steering Fluid Change
a. Use the cheap Wal-Mart pump to remove as much fluid as possible
b. Refill with new fluid
c. Start car and turn steering wheel lock-to-lock a few times
d. Repeat steps A-C until fluid is suitably clean
21. Reinstall wheels (Without Guesswork – Page 44-10)
a. I didn’t know there was a procedure until I was done…not fun to redo after 3 days of work.
22. Drive car and enjoy!
Attachments: Receipts (I’m not affiliated with either, but am very happy with both companies)
1. Pelican Parts
2. Speedlife Motorsports
Things I’d do differently next time:
1. Buy heavier oil. The Motul is a Porsche A40 approved oil, but is only 5W40. I might opt for a 15W40 next time since I live in Florida.
2. Rent a garage space with a lift.
3. Drive it more!
File Type: pdf
Last edited by mapolus; 07-24-2013 at 06:18 PM. Reason: Added Spark Plug wires / distributor cap / rotor to step 13.
Old 09-24-2013, 07:53 PM
ralt
ralt's Avatar
Matt, thats a really nice review of service steps. Thanks. I have the books and you have done the work!!!
Quick Reply: It Runs!
