Power Steering Fluid
My Fluid level is a little low, so I will need to top it up (and source the leak.. I think it is weeping somewhere)
Not knowing what was put in there by the previous rebuild, what should I add without having to flush the system completely?
thanks
thanks
Registered User
Have fun fixing the leak, that thing is a pain in the *** to get to with the engine in the car. If you change the seals be careful, its easy to warp them during the installation. Then when you finally get it all back together and crank it up and it starts leaking again.....well you can imagine the joy.
