Stutter at low revs
Stutter at low revs
Greetings
I've noticed that my car isn't smooth when driving at low revs, in a low gear. For example, if I am in second, driving slowly down a street, the car seems to 'stutter'. Hard to describe without making body movements and audible sounds.
Additionally, every now and then it seems to 'pop' when I rev it. Kinda like a backire, but...
I have had a problem with a leaky boost hose that was causing me grief, but that is fixed.
If I had to describe it another way I would suggest there was dirt in the fuel line, but that may be looking for a solution before diagnosing the problem.
Any ideas?
Any ideas?
Sounds familar...try disconnecting your 02 sensor. It's on the drivers side, more forward in the engine bay. It should be a round cylinder that's snapped into a holder back by the air pump belt. If not, just trace it from your exhaust pipe.
If this helps, your CO mixture is not set right. Hope this helps...
