Miss under power?
Miss under power?
I recently bought my '91 C2 T and have since had the plugs, rotor,cap, O2 sensor and one of the plastic intake air pipes replaced. This was done due to the car running rough. It idles just fine now and once warm runs great. However it has a slight miss under load and once at crusing speed. Does anyone have a suggestion?
Maverick <img src="confused.gif" border="0">
FYI.
Well since I got no feed back I will let you know the cause/solution of the problem. I had the warm up regulator replaced and that did the trick.
