964 Turbo Forum 1989-1994
Dual mass flywheel
Old 09-10-2002 | 12:29 PM
Mike GP's Avatar
Mike GP
3rd Gear
Post Dual mass flywheel
Hi,
I have a 1992 3.3l turbo and it has a dual mass flywheel. the car is smooth, but I am wondering if I can fit a RS clutch in? Will there be any gearbox rattle/knock back? and how much difference will it make to the performance?
Mike
Old 09-11-2002 | 06:28 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Dear Mike,
If you are going to install a RS Clutch assembly I would recommend the single mass flywheel to go with it. I would see little benefit of installing a lightweight clutch and still have the slug of the flywheel. To gain any benefits you have to lighten the whole load.
Ciao,
Adrian
911C4
Old 09-12-2002 | 04:59 AM
964turbo's Avatar
964turbo
Post
hi Adrian,
just curious, do you know who make the best light
weight clutch?
Old 09-12-2002 | 06:18 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Now that is a toughie. To be quite honest I have heard no complaints about the Porsche Factory RS clutch. I know this works well in a Turbo because it was fitted. I also hear good things about the Sachs competition clutches. However these are not cheap. I am sure there are much more informed and knowledgable people who have actually done this work on their Turbos. I would seriously advise you to shop around but please consider the factory parts. I know they last quite well.
Ciao,
Adrian
911C4
Old 09-13-2002 | 09:45 AM
Mike GP's Avatar
Mike GP
3rd Gear
Post
Hi all,
Just interested as I know as the dual mass flywheel takes all the vibrations out the motor, I would lighten the whole assembly (clutch, flywheel, pressure plate).
A lightened flywheel and clutch is worth about 10% increase in power because of the Dynamic mass, that being that a rotating object has 4 times the mass of the stationery object. therefore if you can reduce the rotating mass then your motor will spool up quicker.
Thanks guys
Mike
Quick Reply: Dual mass flywheel
