'91C2T Maintenance Cost Expectations
Q1) What would I expect to pay in normal annual maintenance for a turbo? How would this compare to a normally aspirated car? Are there any particular worries?
Q2) I had heard there may be some maintenance issues for the 1990-1994 cars. Is this true?
FYI - I'm researching the acquisition of a turbo Porsche and given my budget, this is a 930 or '91C2T. Yesterday I drove a '92C2T and a '95 993 in order to get a feel for the turbo vs. non-turbo feel. I liked the turbo which both felt faster and more "sporty".
Thanks in advance for your thoughts.
Lifetime Member
Lifetime Member
Hi jjg,
I've only owned my C2 Turbo since Oct 2000, so I will tell you about the maintenance on my car.
After purchase, I did the alignment, wheels balancing, corner balance. Total $360.
Had Hydraulic brake servo failure. Cost ~$870 for part alone. Add a few hours of labors to that.
Major Service, my first one $1300. This included valves adjustment, tune up, tranny oil change. Fuel enrichment device added, belts change, and a lot of little things from the Technical Bulletins since '92.
This year, up to Oct 2002, I hope nothing breaks, I will only need an oil change as regular service goes. I will need new tires soon.
Other than that, I will spend money on enhancement if my budget permits. I can only hope...
Here is my wish list: Electronic Boost Controller, header system, Forge CBV valve, a set of 17mm spacers with built in studs. A subwoofer system with two 8" JL subs (have amp), a set of S-03 tires, and <img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> a week worth of DE's.... <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
I am done <img src="graemlins/yltype.gif" border="0" alt="[typing]" /> now...
Sonny Vo
Sonny Vo
