Andial Fuel Enrichment
I recently purchased a C2 Turbo with the Andial Enrichment installed. I know it is intended to provide an richer fuel/air mixture under high boost through manipulation of the warmup regulator, but is it reliable and how do I determine the proper settings?
JBH
The fuel enrichment changes the control pressure via a second frequency valve that is installed as part of the kit. It does not change anything at the warmup regulator( the new valve is installed in the line from the warm up reg. to the fuel dist.).The unit has been in service for years and is completely trouble free. We have found the most common postion for the rotary switch to be set at the third postion.( The counter clockwise most postion is off).
Pete.
Pete.
