Recommendation for Oil Cooler
I have a C2 Turbo w/ modifications (SC cams, K29 set at 1 bar, SS. headers & muffler, powerflo, etc. that I intend to take to the track on a regular basis.
Since engine longevity is probably related to how well the engine is cooled, I would like to hear some recommendations for type and location of oil coolers. Does anyone mount it upfront in the forward valance like 930s?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I am confused. Are you looking to replace your oil cooler or install one. Unless I am terribly mistaken there is already one up front. I have seen these replaced with dual placed across the front.
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
Yes - that was an ambiguous post - I am really asking what configuration and cooler style will give me the best cooling for a C2 turbo.
I do have a front oil cooler in the right fron wheel well, but I do not consider that a good location or optimium configuration for achieving maximum cooling.
What are the alternatives? Has anyone put one up in the front valance like the old RSR?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I have heard that two 930 oil coolers (racing versions) welded together and squeezed up there at the front works really well,
Ciao,
Adrian
911C4
PS: There are some old issues of Excellence cover this. Maybe you should also contact the guy who ran the Turbocharged C4 and Turbo S at Pikes Peak in the 1990s. Jeff and I can never remember his last name.
Ciao,
Adrian
911C4
