964 Turbo Forum 1989-1994
Which oil do you use in your 965 turbos?
Old 11-03-2011 | 01:37 PM
kosarn's Avatar
kosarn
Default Which oil do you use in your 965 turbos?
I got an advice to put some Mobile new life 0W-40 in my 965 turbo, since that is recommended oil by Porsche (but i guess that is only for water cooled). With this oil the car smokes like a chimney when you start the engine. Since I don't drive in very cold I guess I could use much thicker oil, but which? Which oil do you guys use in your air-cooled turbos?
Old 11-03-2011 | 05:08 PM
parsecnc4's Avatar
parsecnc4
Brad Penn 20W50.
Old 11-03-2011 | 05:24 PM
Boeing 717's Avatar
Boeing 717
Registered User
Mine used Valvoline 20w50 the entire time and went to 141,000 miles with no problems, so I suppose that stuff is ok. When the turbo was rebuilt the guy said that it was still within tolerances.
Old 11-05-2011 | 06:36 AM
zarpoxx's Avatar
zarpoxx
20w50 too.
Old 11-05-2011 | 01:37 PM
Gandara's Avatar
Gandara
I use valvoline 20w50 as well and I am at 106k miles
Old 11-05-2011 | 01:46 PM
kosarn's Avatar
kosarn
are you guys talking about Valvoline VR1?
Old 11-07-2011 | 09:15 AM
RichiRich's Avatar
RichiRich
Over in Europe I'm using Castrol Magnatec 10W40
Old 11-07-2011 | 11:55 AM
C2 Turbo's Avatar
C2 Turbo
Mobil 1 15W50
Old 11-07-2011 | 02:09 PM
gr1275's Avatar
gr1275
Currently Brad Penn 20W50. Prior to all the discussion on zinc etc, I was using Castrol 20w50...
Old 11-07-2011 | 06:08 PM
Metal Guru's Avatar
Metal Guru
Here is good info that should help us select the correct oil: http://www.lnengineering.com/oil.html
BTW, Brad Penn 20W-50 is API "SJ' rated.
Old 11-08-2011 | 06:14 PM
Max964t36's Avatar
Max964t36
FUCHS motor oil TITAN Supersyn 5W-40
Old 11-20-2011 | 06:06 PM
RPCORP964's Avatar
RPCORP964
Mobile 15W 50
Old 11-22-2011 | 09:31 PM
ralt's Avatar
ralt
Shell Rotella T 15w-40
Old 11-23-2011 | 09:42 AM
No HTwo O's Avatar
No HTwo O
Mobil 1 V-Twin 20W50 would be a good choice too.
Old 11-23-2011 | 10:07 AM
Metal Guru's Avatar
Metal Guru
I haven't heard one person talk about oil ratings and ZDDP levels.
Are you guys sure that you are using oils that will protect your camshafts?
Quick Reply: Which oil do you use in your 965 turbos?
