Correct connection for EZ, BOV, and EBC
I searched and could not find the answer the 965s (or at least the 3.6) have three vaccum ports. Looking from the backand over the TB (without the IC), there is a T connected post butterfly with the right side connected to the WUR and the left side I am currently using for Zeitronix and AIC Injector and Boost Controller. Then there is one more port slanted to the right that is pre-butterfly and on my car is connected to the EZ and Bypass Valve. I am concerned that the EZ should not be connected to a pre-butterfly port.
Just wanted some confirmation on this:
Electronic Boost Control Signal -> Post-Butterfly
WUR -> Post-Butterfly
EZ -> Post-Butterfly
Bypass Valve -> Pre-Butterfly
Does this sound right? Are there any other ports available? I read a thread mentioning a port on the left side of the intake manifold for use with the EZ?
If anyone can confirm the factory conection points, that would be greatly appreciated.
Agree with everything except BOV referencing to the intake manifold pressure rather than pressure between the compressor and throttle body? Not that I want to question a GURU but you sure about this one?
Thanks for your reply, I have to find original port for the EZ which concerns me the most.
