964 Turbo Forum 1989-1994
Maint question.
Old 07-28-2011, 04:27 PM
Boeing 717
Registered User
Boeing 717's Avatar
Originally Posted by C2 Turbo
Well now i can't sleep
Care to explain what the heck WUR is and what are the symptoms of this bad boy going wrong
I think symptoms are a hard start and rough or no idle when cold. I think there is someone who rebuilds them if im not mistaken.
http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
Old 07-30-2011, 04:58 PM
Metal Guru
Metal Guru's Avatar
Wur stands for warm up regulator or officially known as the Control Pressure Regulator. Briefly, when air is pulling down the air flow flap in the fuel control, the control pressure regulator is supplying counterbalance force to the system which dictates what the mixture will be given the air flow/throttle opening. There are three pressures; cold control pressure for cold starting, warm control pressure for normal operation and boost control pressure, which provides enrichment for boost.
When the wur goes bad you will know something is wrong. Your car won't idle well and will be pretty much un-driveable.
Old 07-30-2011, 10:24 PM
John McM
John McM's Avatar
I have owned my Turbo 3.6 for 10 years. When I book it in for check-ups etc the mechanics get genuinely excited about seeing it, not because it's made them rich, but more because it's that special to them; remember they see everything.
One of the positives out of the way, these cars are not for owners with short arms and long pockets. At some stage they will cost you and as mentioned before in this thread it's often time spent chasing small problems. Right now I'm compiling a refresh list. You wouldn't see one single thing I will likely change as it will be rubber hoses, bushes etc, but it will cost.
They say you can tell a lot about someone by how they react if they lose their luggage. I would suggest that if you have the maturity to take the knocks as they come through then you will love owning one of these cars. On the other hand if you expect an 18 year old car to be perfect then you will be disappointed.
Old 07-31-2011, 10:35 AM
RichiRich
RichiRich's Avatar
Currently at €10k in 2 years, but does include new suspension (inc. strutbrace), new rear rotors and pads, steelflex brake lines, powder coated callipers, new front tyres, different (larger) set of (used) alloy wheels, etc.
The biggest cost for most of it is having to take parts out to get to others and it seems to take a lot of time to diagnose what the problem is (no matter which Porsche specialist you use).
Old 08-02-2011, 08:25 PM
EnglishBulldog
7th Gear
EnglishBulldog's Avatar
Nothing is perfect, except my wife, and yes, she is standing behind me.,
Quick Reply: Maint question.
