Well a race car is totally different or a car that is trailered to the track for that matter
I drive it on the street and to the track on the tires I run And these past mid oh weekends have been awful cold and damp and the track slow.... I awoke degrees my car covered in frost Fast lap of the weekend was in TT... unlimited tuned insane vette @1:35 Fastest race car qualified at 1:39.9 and was only race car to get under 1:40 http://www.racewayvenray.mylaps.com/...jsp?id=1846432 |
I only share for comparison purposes.
Originally Posted by Frank 993 C4S
(Post 8521104)
I don't track my turbo but I could imagine that it would be quite a handful given the way the power sets in. You'd have to modify the engine/exhaust set-up quite a bit for the power to come out more linear - not sure whether this can be done.
If you click on the link below and scroll down you can see a simple diagram with the TQ curve of a RUF RCT (note, not the EVO version which is even more powerful) vs. an NA 964. http://www.rsamerica.net/articles/member/RUF-RCT.htm |
This one is set up wEFI and the right Turbo for track work.
http://forums.pelicanparts.com/porsc...ml#post6020605 Elliot |
tracked 965
Hi,
I've recently been tracking my 965 and below are the changes I've done to the car. I've tracked the following cars (1988/1996 (E30/E36) m3's, 81 911SC, 96 carrera and finally this car. This is my first turbo and as I felt like a four wheel drive and twin turbo might be "cheating", I thought I'd be completely stupid and put my life in danger by going with the 965. However, after 4 events, I find the turbo to be quite linear and not an issue to handle at all. As far as my track times, I've moved up to the fastest run group rather quickly POC (track record at one of the events with 60 other Porsches). This is mainly due to the ability of the car, not my driving. However, I don't suffer from fear as much as I should which might contribute to the decent track times. With that, here are the "mods" in order of biggest impact: Tires: Michelin Pilot Sport Cup 3's and these tires are not cheap but give excellent feedback and grip. This is where I would put ALL my money if that's all I could have done. Purchased used turbo twists (solid) to protect the speedlines. Suspension: H&R lowering springs (ROW?) with bilstein HD shocks Brake Fluid: Bleed, Bleed, Bleed!! I had my brakes go out COMPLETELY due to improper bleeding (even with superblue) so make sure you get someone who really knows what they are doing. I know, I know, you can do it yourself, but I I thought I did it right and almost died! I've done it successfully on all my other cars and no issues til this one. So, I ended up taking it to a Porsche Dealership Meister mechanic, one of only 27 in the country and no problems since. Brake Pads: Pagid Blacks with stock rotors have not faded at all and inspire confidence. (I did this the same time as fluid bleed #4 as I was concerned about boiling fluid/overheating the brakes) Heal/toe: Rennline pedals and all I did was the acclerator to ensure a smooth transition between brake and gas. Corner balanced- Considered Mods but didnt do: Brake Ducting- None, standard scoops work fine and that was in 105 degree heat at Willow Springs short track. Anti-Sway Bars- Stock strut brace- none bigger turbo- NO WAY as HP is not this cars problem! Exhaust- better turbo linearity and HP, but didn't want to mess with smog and felt stock was fine. Only remaining Wish: Harness to hold me in my seat Better Driving Skills EVERYTHING else is completley stock and you should be able to have quite a bit of fun with the above mods. Hope this helps and this is only my opinion! |
Originally Posted by tasracer
(Post 8520970)
Not all that hard to handle...
Just got back from mid Ohio running in the advanced group and was eating new GT3 RSs for lunch Only thing that got me and only on the straights was a new GT2 But my car is track modified |
Since I was a unknown to the PCA club they put me in A but had an instructor run with me for the first 2 sessions
When I let him by I was kinda bummed thought it was just a gt3rs... I was busy driving but my ride along saw the emblem and said" no shame there.... It's a gt2 not one of the gt3s" Found one Uploading to YouTube now |
Uploaded from iPhone to YouTube but I can't find it
Awesome track vide
Tasracer,
That video was awesome and had me smiling almost as much as being in my own 3.6 turbo. Actually, I was smiling a little more as it was your tires that you were wearing out and there was no risk of me totalling my own car! Great driving and thanks for sharing!!:bowdown: |
Originally Posted by DM993tt
(Post 8564331)
Video or it didnt happen.... :)
Note the 2 white gt3rs way in front |
