Received My PPI Results Today 91 964 Turbo
I received the call this morning on the results of the PPI on a 91 964 Turbo with 73K miles that I'm interested in buying. I asked for a compression & leak down test, had them look at a small oil leak and why it had a pull to the right.
The pull to the right was from a bad alignment, they did a 4 wheel alignment to solved the pulling issues.
The oil leak is from one of the valve covers and is very slight, and suggested not to replace the seal at this time.
Here are the compression/leak down readings.
1 125 5%
2 125 6%
3 125 4%
4 125 5%
5 125 6%
6 130 3%
The tech said they were good numbers with 73K miles. Do those numbers look in range for this year and miles? Thanks
1 125 5%
2 125 6%
3 125 4%
4 125 5%
5 125 6%
6 130 3%
