964 Turbo Forum 1989-1994
Trouble Shooting the Tach Signal
Old 08-06-2010, 01:22 AM
benzyne
benzyne's Avatar
Default Trouble Shooting the Tach Signal
Rennlisters,
Does have advice on trouble shooting the tach signal on a 1992 964 Turbo? The actual Tach works ... I've tried two tachs on my car and a friends car ... so there's something missing from the signal that car should be giving.
I've heard the black/purple wire provides the signal but I don't know where it goes to after the tach.
Cheers,
Ben
Old 08-08-2010, 09:46 AM
Miles965uk
Miles965uk's Avatar
Im no expert but the EZ69 provides the signal.
It goes to the box underneath the left seat into a control box.
From there it goes to the tach.
You have to check it with a scope to see if its giving a signal... could be the EZ
Please post your findings, im having trouble myself after converting it to EFI- it was working fine and now has stopped.
Look at the electrical diagrams for tach from teh EZ and follow.
Old 08-09-2010, 09:33 PM
Francisco Martinez
Francisco Martinez's Avatar
Hopefully this can help you start the troubleshooting,
OBC Pin #
1 Pin #4 of clock (+12V power) red
2 Stock tach harness pin #2 (ground) and OBC stalk pin #1 brown
3 Stock tach harness pin #3 (turn signal LH) black/white
4 Stock tach harness pin #4 (high beam) white/black
5 Stock tach harness pin #5 (turn signal RH) black/green
6 Stock tach harness pin #1 (lights) gray/blue
7 Not used -
8 Temp sensor pin #1 blue/green
9 Central indicator (informer) pin #7 beige connector (fuel signal) brown/black
10 Temp sensor pin #2 brown/green
11 Not used -
12 Pin #2 of speedometer (speed signal) white/red
13 Pin #4 of connector behind LH kick panel (door armed signal) green/white
14 Stock tach harness pin #7 (tach signal) orange
15 Stock tach harness pin #2 (ground) brown
16 Not used -
17 Not used -
18 Not used -
19 Not used -
20 Not used -
21 Stock tach harness pin #6 (tach signal) black/violet
22 Pin #6 harness under seat from DME (TI signal) white/green
23 OBC stalk pin #2 white
24 OBC stalk pin #3 green
25 OBC stalk pin #4 blue
26 OBC stalk pin #5 gray
Old 08-10-2010, 12:58 AM
benzyne
benzyne's Avatar
Francisco, that is very helpful. Thank you. I will take a look at it sometime this week and will report back.
Quick Reply: Trouble Shooting the Tach Signal
