Blownsix AFR/combi gauge wiring
Hi guys,
One of my customers got one of those Blownsix combi gauges that has the wideband AFR gauge, boost pressure and EGT all in one, but he has no instructions or wiring diagram for it. I posted this on the 993TT board but no dice; it looks like a couple of you 965 guys have installed it.
Most of it looks straightforward, just need to run power/ground/illumination circuits, install extra O2 sensor/EGT probe and boost sensor. However, it comes with 2 switches that I do not know the function of, and both the switch connector and the wideband O2 sensor connector are the same 3 pin and I need to know which is which; I don't want to risk trial and error since the company doesn't seem to be around anymore and I doubt I could get a replacement.
So, has anyone installed one of these and still has instructions and a wiring diagram for it?
Thanks!
Thanks!
