H4 headlight help
Unable to adjust the headlight on the driver's side I removed the assembly. I discovered the black gasketlike pieces that hold the metal tabs that the adjustment screws thread into have fallen apart. I searched through Pelican but can not find these parts. Also, I need different headlight screws for the trim ring (both outer and inner) Pelican only offers for the models 1968-86 -I assume those would work on my '91, as well.
The black plastic pieces are stops to hold the screws in place. You should be Ok without them. Are the screws connected to the brass pieces that move the reflector?
Yes, the brass piece is connected to the lens via the "rubbery" black piece (looks kinda like a hose but with very thick walls). The adjustment screw threads in or out of the brass piece. This in/out action moves the brass up and down the adjustment screw thus moving the lens. But the black pieces broke apart (dry rot?) allowing the brass part no connection to the lens.
