3.6t maint schedule?
Valve adjustment every 10K or so, maybe run it out to 15K. Gearbox change every 10K to 15K as well. If the car is in a wet or humid climate flush the brake fluid every 2-4 years. Alway check tire pressure make sure your not low, speedlines can have very slow leaks. I do oil changes every 5k with Elf/Total Elixium NF 5w-40w Euro blend synthetic. I would change the oil every 2 years if you dont put the miles on it and maybe every 4 on the gearbox.
