New Turbo Purchase...Best place to purchase....
Our '91 has the original CD2. It doesn't have a seperate sleve or bezel. It slides out using the tools in the manual. Be very careful removing the connector as it doesn't seem to be very robust. I've had mine out a couple of times to have the CD repaired and ended up replacing the cable going to the amp because of broken wires. FWIW, I have not been able to have this one repaired nor have I had any luck sourcing a reliable replacement. If I actually used it, I would replace it with an aftermarket unit.
Gary
Gary
Since my CD skipped every time I hit a bump I replaced it with a CD220.
I believe so
so is the CDR-210
so is the CDR-210
It's my understanding the CDR-210 is 993 vintage whereas the CD220 may be 996/Boxster. Paul, is that where you sourced yours? How did you handle wiring it to the stock cable and amp?
The one issue that has prevented me from buying an aftermarket unit is that I like the appearence of the stock Porsche units. That's not a great reason, but it works for me.
Gary
Gary
I agree
I picked up a CDR 210 unit off of flea bay yesterday so I can turn mine back to somewhat original stock. Although its the wrong head unit for my car it is a Porsche unit and it will look better than the silver cheesy one in the car now.
Just hope I dont have tooooo much trouble with the wires.
What happens with the wires is the big question, I'm waiting on Metal Guru to get back to me so once I hear from him I'll let you guys know. If it is simple plug and play that'd be fantastic!
