Anyone have an alternator die on them while driving? - What might the symptoms be?
My car died today while driving it. I had a bit of hesitation first when attempting to accelerate and then over the course of the next mile the car more or less died (no smoke or leaking of any fluids) and I coasted to a stop after some serious backfiring. Fortunately for me I made it off the highway and got it towed to my tech who said it sounded like the alternator.
Thanks in advance for any wisdom.
Cheers,
Cheers,
Registered User
I had an alternator die on me once, not in my porsche but a nissan, the car just sort of started to lose power and the lights got really dim and it just finally quit. It was kind of a slow death over a minute or so. Hope its nothing serious.
When my fan belt broke I drove my car to the shop.
The battery light was on (since it wasn't charging) but the car run okey if I remeber correctly.
Shouldn't the battery light be on if you have a alternator problem?
Doesn't it bevave like it's electrical or could it be an air leak?
I had the same syptom on my car when the hose to the CBV was coming loose.
I would also ground the overboost switch.
Did it hesitate when pressure was building, that would indicate an air leak imo?
Usually when the alternator dies and the battery is drained the tach and other gauges will start acting up. The tach needle will bounce from 0 rpms to redline and back.
If it is your alternator then the battery light should come on. Start the car and then on purpose stall it. If when the engine dies the battery light comes on then it's probably not your alternator.
You could of course hook up a voltmeter to the battery and compare the voltage of the battery before you start the engine, when it's idling and when your are revving it up to say 4K RPM.
