GUT THE CAT???
My car is actually as quiet or even quieter than running the cat and muffler bypass. It is a nice sound that is not much louder than some new cars are today. The advantage is you can hear what is going on and there is the traditional turbo burble on lift off. I think if you go with a cat bypass you will find the differences would be minimal db wise but you would still retain that brick of a muffler hanging over the rear wheels.
Either way, I'm not too obsessed with weight reduction, just want to keep the car close to stock but get the easy/cheap hp gains that are available.
The secondary muffler is actually very free flowing. The only way to get a real performance gain is to remove the cat. Removing the secondary muffler will save a little weight and with a G-pipe will add noise but not much performance.
That seals the deal for me, I'll just be doing away with the cat and keeping the muffler stock. Does anybody know if the little miniature catalytic converter coming off the turbo is worth gutting? I assume there is some restriction there also...
BTW go to off topic a plane crashed into the Hudson river a short time ago. I saw it coming down but didn't see it hit.
http://www.google.com/hostednews/ap/...zhzqQD95NRK0O0
The wastegate cat, does not restrict.
The only benefit of removing is the sound. You can pootle quietly around town off boost, but when you hit full boost your car will 'shout'. Ideal for stealth in traffic, and fun at speed. But pcar, sounds like you want stealth all round, so will be too loud for you. ;-)
So I talked to a guy at my local Midas shop, he says if I bring in the catalytic converter, he can custom make, with the correct flanges, a straight pipe in stainless steel to fit where the cat went. Total cost under $100!! Am I forgetting something here, or is this a good option? What size should I have him make the pipe, 3"?
Pcar....
Gutting a stock converter is not as easy as it on some other cars. The core is metal not ceramic and getting the old stuff out of the can is not an easy task. It doesn't just break up like the ceramic ones.
I think there is a benefit to using the stock gutted pieces. The first is the fit and finish. Everything fits and lines up as it should and it all looks stock underneath. I despise the way some of these aftermarket parts fit. It pisses me off that they charge the money they do and the parts don't line up as they should/could. I just don't get it.
Anyway, your biggest performance benefit will be removing the cat. You can do this with a bypass pipe or with a gutted cat. BTW, someone else mentioned the gutted cat will have a funny sound (or something to that extent). I for one like the way cars with gutted cats sound. It has a unique sound, and I like it.
Removing the cat will make the car louder, but it's not that bad. You should probably get a ride in one before you go any further just to make sure it's not too loud for your tastes.
The second thing you can do is replace the secondary muffler. As a number of people have commented, there is not that big a performance gain in doing that.
I gutted my secondary muffler instead of replacing it as I want my car to appear stock and I want all the pieces to line up where they should.
The downsides of gutting the cat are the value of the cat and the weight. A bypass pipe will cost less than a spare cat and it would be lighter as well.
Good luck....
Good luck....
Thanks Mike, that is why I'm thinking of having my local muffler shop just fabricate me a test pipe. It's not that complicated, just a pipe and two flanges - and I'm with you, I have NO IDEA how aftermarket tuners come up with those prices for a simple pipe - it's insulting that a person would be asked to pay $450 for standard 3-4" stainless pipe just because it's a Porsche.
http://www.scart-exhausts.com/ang/de...php?produit=98
PS: no affiliation, just a very satisfied customer.
Or spend a little more, and get a quality product for your supercar:
Mike, don't see what you mean. It fitted perfectly.
Anyway that's me outta this thread, I spent a lot of time and money working out what's good for our cars and what's not worth scimping on. Personally I found butchering exhaust pipes a PITA.
