car veers a little left under hard accel
have to add a tad of right steering...
then if i abrubtly lift.. car veers slight right and slight left steering adjustment as well
just got an alignment after install of the jic cross susp.
good steet/track alignment
Registered User
I have same problem tas, except mine goes left when i lift or accel. I know my car needs a full alignment because my right rear is wearing bad on the inside of tire. I figured it was an aligment issue let me know what you find out.
Hi tasracer,
there's a lot more to the tweaking of a 964/965 chassis.
Beside the alignment there are things to consider like:
- wheel load (important! separate, more difficult adjustment, you need special balancing systems)
- tire pressure
- wheel spacers
etc.
To really work it out to have go through these one by one.
Cheers,
hvh
- tire pressure
- wheel spacers
etc.
Cheers,
hvh
Hi tasracer,
- tire pressure
- wheel spacers
etc.
- tire pressure
- wheel spacers
etc.
Tire pressure was already discussed. When I had a low tire my car pulled on downshifts only.
Wheel spacers? If one was missing maybe but I doubt it.
I like Nathan's idea of a dragging brake but, once again, I think one would feel that all of the time.
Hi Metalguru,
you're right with your reply. Add please the recommendation about the brakes to the list. The point is I finalized with is: "To really work it out to have go through these one by one". We're talking performance sport cars here and they need a very good setup overall. So check off each point one by one and it should solve the problem (additionally also add wheel balance).
Regards,
hvh
Regards,
hvh
