Ruf done it!! (boost gauge)
#31
Unfortunately, no.
I thought I had a line on someone local (New Vintage Gauges) but they said they don't have a Porsche technician to do the work.
I'm checking with with North Hollywood Speedometer now.
#32
Custom PLX gauge in clock... Still avail?
Hunting...
5 years later... having a little trouble sourcing the people who do/did this conversion and/or any actual parts avail. Any current info on this?
This is a peak at the new clock and a custom 8k tach they are to be released next week. We work with NHS on alot of our gauge conversion and every thing that kevin does is top notch I know they will have an anolog boost gauge for the 993 tt and the 964 very soon and there is no ? it will be nicer than RUF's gauge!!!
#34
The gauges in my turbo used to be on his website. They worked nicely it is a shame nobody does this anymore.
https://rennlist.com/forums/964-turb...on-manual.html
http://forums.pelicanparts.com/porsc...ce-gauges.html
http://www.plxdevices.com/
I had mine installed in a non OBC tach saving my original tach if I want to put it back to stock. Far easier to read under acceleration than the clock and far more accurate. I am sure it will take some work but can be a DIY project if you have the skills.
#35
Found that one in Germany ... not so fancy like the others (more 930 3.0 oriented, I guess) but it does the work.
#36
The problem with that gauge is that you lose the warning lights in the clock as well as the fact that you need the alternator warning light in the clock as it's part of the charging circuit. I've heard that some people install the 930 boost gauge and leave the clock hooked up, sitting behind it.
#37
For my 964 C2 twin turbo project I have been researching this type of gauge. I think I have found the right guy to do this in The Netherlands where I'm from.
Talking to him I certainly got the impression he knows his stuff.
I need a mechanical pressure gauge for my project, as I have a 1990 C2.
Anyway, he is building a turbo pressure gauge right in my clock and it get a new faceplate of course.
Should be done in a couple of weeks, I'll post results.
#39
i found the needle in a haystack and got myself one of these gauges with drag indicator. its original VDO from 1979 and has been used in 934 to 962. think it increases worth of my 965 by nearly 50% .....
#40
advantage of leaving the clock connected behind the dash is that you don´t have issues with the central indicator (exclamation point in the tach). in order to get the battery charged it is sufficient to use another unlined bulb in one of the other instruments as charging warn light. there is just need for exciting current.
Here is the gauge they used in the 962. This is the Rothman's car. My friend has one of them and they are very poorly built.
