265/35/18 or 285/30/18 on rears?
Thanks for the clarification
Thank You
I guess what I meant to say Anthony is how does Rolling Dia come into play. I noticed from this forum that the 285/30 Rolling Dia is lower than stock. How does this affect the handeling?
Handling is subjective I guess. There are pros and cons to any changes. Wider tire better contact patch, this is good assuming you have enough down force to take advantage. Although at the same time you have a different fit to the wheel so the large dia on a 10" wheel will give you less sidewall strength or more sidewall play in the turns.
I haven't heard any negatives from the people I spoke to. Chris my local tire guy is considered very good and he gets invited by Perelli to be a tire technician at LeMans every year. He was all for going with the 225/285 or 235/295.
I can't comment any further because my car came with the 225/285 setup to start.
Somewhere in here https://rennlist.com/forums/showthre...highlight=tire
Thanks for pointing that out. Was quick typing. Shouldn't do that.
One other point I forgot to mention the 235/40 295/30 MPS2's came stock and are N rated for the 996 GT3.
Agreeing with Cobalt. But each manufacturer seems to lie about the aspect ratio or sidewall height of the tyre as a percentage of width. Some tyres have stiffer side walls than others it is a bloody nightmare.
SO2's are a great tyre; I had them on my Supra and they were really good all round.. in addition they wore surprisingly well.
Yeah the worn tyres i replaced were S02's, they were good, apart from the noise. I look forward to getting the RE001's off and some new S02's back on, they were a nice predictable tyre, with good stiff sidewalls.
