Weight Saving Measures for a 965 Road Car (Fairly long post)
AV,
What do you mean about the flywheel? These weight savings are the ACTUAL weight differences of the components, therefore saved 11kg immediately :-)
As the weight reduction is at the flywheel, the effect is much greater than the pure weight saving. Is this not UNsprung weight? Maybe I have not used the correct engineering term?
AV,
correct me if I am wrong.
I was always under the impression unsprung weight had to do with anything hanging off the axles. So tires, brakes, wheels, rotors etc would all affect unsprung weight. Sprung weight had to do with anything to lighten the car, Seats, exhaust body panels etc.
Rotating mass is "another thing", where you will have a more rapid respons if that weight is low when revving the engine. That weight includes wheels, tires, discs, drive shafts, flywheel etc.
Edit:
http://en.wikipedia.org/wiki/Unsprung_weight
Edit 2: spelling error
