Please, advice about K27 HFS and LFW
911addict.........
3.3 litre.....electronic ignition (it is a 965 engine)
964 cams
1.2 bar spring
Fabspeed cat bypass and Fabspeed muffler with dual outlets
Imagine Auto K-27 HF "S" turbo
Imagine Auto fuel head conversion
FVD ignition sensor mod
BMC filter
Stock intercooler (stock 965 - full decklid)
Fresh internal rebuild with complete valve job
375.6 HP at the rear wheels.....on a Dynojet 248.
32 degrees celcius......25% humidity.......3,300' above sea level.
964 cams
1.2 bar spring
BMC filter
911addict.........
964 cams
1.2 bar spring
BMC filter
964 cams
1.2 bar spring
BMC filter
I mean the factory 965 ignition, which is crank fired and connected to a control module, which was a big improvement over the 930.
We chose to run 1.2 bar because we had the spring on the shelf (main reason) and the cams.
