Injector and Fuel System
964 Turbo Heads,
What is the protocol for cleaning our injectors and fuel system? When should it be done? How do you go about cleaning the system?
Rennlist Lifetime Member
You can run three bottle of Techron Chevron to start. One with the next three tanks of gas. Or you can pull the injectors and send them out to be cleaned and tested. I also can do it. You could buy the tool but it is about 500.00 for a injector tester.
Also, what is the best/most cost effective practice?
1. Test the injectors and replace any out of spec ones
2. Try to gather up a couple sets of used ones and test them all to get the best matched 6
If #2, does anyone have any laying around?
Lastly, who has the best prices on new ones? Is there a Bosch part number or a cross reference to another vehicle?
You probably are very aware of this but since this was posted in the 964 Turbo not 993 Turbo forum thought I'd just make sure - but the 993TT injector will be very different from the 964T injector as the 993 has Motronic EFI whereas our cars still had [already ancient even way back in 1991] CIS.
