Brake Pressure/ Fluid Warning Light
On my T2 this light sometimes comes om when i am accelerating hard for some reason.......(i have only just had a B&B full system HFS turbo and Tial wastegate and high flow air filter fitted)......after stopping and turning off the engine it wont come on again straight away....its seems very periodicaly would the work i have had done effect this...i did have the brake fluid only changed last year and it is still on the max level
any ideas
cheers
Richard
any ideas
cheers
Richard
check your brake fluid level. You might be a bit low.
Thanks 993 C4S but the fluid is on the "max" level.
It now comes on just about 5-10 mins into a drive or if i just pump the pedal 5-6 times in the garage
The manual says "The pressure reserve maybe to low" where do i fill this up
Any other ideas
Any other ideas
Strange I had the same symptom but my brake fluid liquid was just to low (or in fact it wasn't but the brake pads were so worn out that the level dropped to the limit). The light would come up while accelerating or driving on a bump. Turn the engine off and it's gone for a while till the next bump in the road. Good way to see you have worn your brake pads if (like me) you are to lazy to check it out !
Lifetime Member
Lifetime Member
Do a search on "brake booster" on this forum to find more information. This topic comes up every few weeks.
click search on top of this page (right of New post), chose Advance search, and pick 964 Turbo forum.
