AC Compressor Part Number
It looks like I will need a new AC compressor for my car (1994 3.6T with R134). Original Porsche part from dealer is over USD1000 but there is a Denso supplier locally I will try.
Does anyone know the Denso part number as I can only find part no 471-0130 or 10PA15C for a C2/4 (not turbo) on a Denso web site .....densoproducts.com/resultsApp.asp?AAIA=1382587&productCategoryID=5.
Cheers
Paul
Cheers
Paul
I've been told these would also fit/are the same thing ?
Type nr. Toyota 04881-14040
Type nr. Rover (Honda) 10P15C a/c comp.
Check it out, might be a lot cheaper than original P (and since when does Porsche make AC compressors anyway ;-)
Cheers, Paul
Cheers, Paul
I found the attached link that shows loads of different manufacturers alternative part numbers for our cars so I thought I would share it with you
http://69.41.234.197/912E%20Tech%20Data/Parts912E.pdf
