Just wanted to say Thanks
Thank you to all who helped me with my sway bar/s decision/purchase.. Dan Jacobs@ hairydoggrrrrage, Austin @ TRG, The folks @ Rennsport Systems, Nick @ AJ Usa, Geofferey @ Racetekengineering and last but not least my installer Lenny @ European Autoworks in West New York, NJ...
Rey
p.s. Special thanks to Rennlist dot com
Rey
Agree, it's a fantastic forum with lots of helpful people.
Using this forum I have solved each and every problem I had with my car the last 5 years!
Rey, I have been looking for this.
What did you decide to buy (brand, dimension etc.)?
Staffan I went with the rear 3 way adjustable from AJ USA and the front 5 way adjustable from TRG with the RS links. I believe adjustable front links were available from Kelley Moss Racing but I chose to use the RS links instead. I know some feel this set up is not the proper set up ( while others say that this is the only set up..aside from a custom set up ) for the 964 turbo. In the end I went for it anyway and may I say wow I love the new handling. Hope this helps..
Rey
Rey
Rey
Rey
Rey,
Wow that was fast. I didn't think you were in a rush but I guess you were. Sorry I was of little help.
Did you use the rear factory drop links? Do you mind posting the specific info for what you bought. I am a bit too busy to do anything now but am thinking of doing the same in the future.
Don't mind if I do. The rear bar is the AJ USA rear bar( 21mm) kit. It is supplied with the links. Unfortunately AJ USA no longer sells this kit because because it's missing a couple of parts.. I spoke with Nick at AJ USA and he explain the parts( very minor parts ) that were missing..I decided to purchase it anyway..Well to my amazement it took about 30 min in Lowes Home Improvement center to find an equivalent part.. I believe not many kits are left. So for those who want to purchase the kit feel free to pm me as i saved the part# of the item you will need to complete the kit.
Anthony the rear bar might be equal to the Porsche motorsport bar you have on your car now( I think ). The front bar is 25mm 5 way adjutable using RS links. My impatience got the best of me ( and I'm glad it did ).
p.s. Anthony I finally recieved my steering wheel.. size is 320mm..niiice leg room..
Thanks,
320mm huh. Got pics?
