Stiff brake pedal - No braking!
I was planning to be out with the 964 crowd today in Wales, UK for some great driving on great roads.
However, on the way there, about 2 miles before the meeting point, the brake pressure warning light came on and the beeper started to sound but, i still had good braking. We arrived, chatted for 30 mins and got back in the car. The warning light was on but no beeping and still good brakes. After about 10 miles though we started on some twisty roads with undulations when, as i went for the brakes, the pedal was stiff and right at the top of the travel.
Well, that was the end of that. I managed to get the car home and started on the books and searches.
I have checked there are no leaks near the booster and that fuse 15 isn't blown so i'm hoping it is going to be relay R51.
My R51 has a 964 code to it but i wondered if there was a VW/Audi/cheaper/easier to obtain alternative relay parts that would fit? Is there also any way to check that the relay is or is not working before buying another?
Also could anybody suggest what, if not the R51, could be wrong with the braking system to cause this. The car has been off the road for four weeks or so and the wheels have been off in that time but i've not been near the brakes.
Any help as usual would be appreciated.
Originally Posted by 38D
Check that the plug on the pump has not come loose. Happened to me in a race once.
Is there a way of bypassing the relay - i've heard stories of bypassing the DME on n/a cars using paper clips. Would this work to get the pump running?
Here is the electrical layout of the relay.
Can i bypass this somehow to get the motor to run without the relay in place to run a simple test. I tried tonight but my High School physics must be rusty - the paper clip i used to bridge the circuits melted the rubber gloves i was wearing
Originally Posted by Sal 965
Which plug on the pump are you referring to? Everything seems to be as it should but i can't get hold of an R51 relay for a few days just to test if it is that.
