I want my oversteer!
Okay, I've searched the archives but with mixed results. I'm adding H&R lowering springs with bilstein HD's and want to add a rear sway bar as well.
In looking at the archives, I've seen sizes from 18MM to 25MM. As I love oversteer, I want to stiffen the rear end and leave the front as is (softer) for now. I want to go with a larger rear, but how much?
Any input on this as well as where to buy, manufacturer, and cost would be great.
Thanks,
Kevin
3.6 turbo
Thanks,
Kevin
3.6 turbo
Not answering your question, but springs, dampers and sway-bars works together.
Personally I would go with the recommended springs and dampers for your car together with stock sway-bars, and get the feel you want by aligning the car with much more negative camber in the front compared with the rear.
Adjustable dampers would be another way to deal with it, perhaps the Bilstein PSS9.
