My new wheels.....
This is a pic of my car at Brands Hatch for the Porsche event. Nathan from 911turbo took this picture of my car. I have to say myself im pleased with my new wheels ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Fully polised 19" cargraphics with 11.5J ET 8 Rear and 315/25/19 tyres.... sticks like glue.....
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Originally Posted by Sal 965
Miles,
Only one word....
Awesome.
Only one word....
Awesome.
How is the ride with 19's?
Thanks guys! The 19s are ok actually... not too hard at all i think thats got to do with the H&Rs maybe. Even the 25 profiles at the rear dont seem to be that harsh... howeveri think i will raise the rear very slightly to let the rear wheels be more forgiving on bumpy roads- its skips a little.... any ideas? perhaps i lower the pressures as well.
Wow that is freaking sick!
I would be EXTREMELY careful lowering your tire pressure, as you are only running a 25profile, by lowering the tire pressure the side wall of the tires will now have much less "give" and an impact or blow from a pothole or manhole has to now be absorbed by the wheel instead of the tire's side wall - which is what causes these high dollar wheels to bend. This is a VERY fine balance to achieve when running these ultra low profile tires. Ask me how I know!
Good luck and be careful...I am sure you have a King's Ransom wrapped on those boots.
Yasin
Yasin
Beautiful Miles. I'd, actually, try to raise the rear ride height a bit so it has a nice rake to it. Slownrusty is right, don't lower the tire pressures on the 19" wheels.
yes thats right its needs some rake to it. These cargrahpics are from a 996Turbo but the offset wasnt right- the fronts stuck out too much and rears too far in so i bought wider outer dishes and swapped the centre stars over and walla.... perfect fit front and rear so now i will go back to my alignment guy and get him to put in a rake.
I am running 39psi rear and 34 upfront (235/35/19) is that cool you think? thats what michelan reccomened but couldnt find yoko rating... same i guess.
good point on the bending - i need to be careful- i did notice on the old rear outer rims one was ever so slight bent and they are 265GBP + 100 fitting a peice....
