Do I need a new clutch?
I noticed a slight flutter or vibration when taking off in first the last couple times I've driven my car. If I rev it up a bit it doesn't seem to happen. It doesn't happen every time but when it does happen it is noticable. Any suggestions? Everything seems fine when shifting and otherwise.
Easy way to test this is to put the car in 5th gear at 2.000 rpm and floor it, it can be done on 4th gear as well but most effektiv on 5th gear, if it starts to slip when the boost builds up you have a problem related to your clutch.
How many miles on your car ?
I have more than 90.000 km and never changed the clutch, had it cleaned from dirt (oil I think) once.
Not to uncommon that the rubber seal between clutch and engine starts to leak.
Had a problem with my clutch last season when running Mobile 1, change to Castrol TWS this year and had no problems (not really blaming the oil here, pointing out the possibility of a leak that get worse by Mobile 1).
