964 Turbo Forum 1989-1994
3.4 Conversion
Old 03-10-2005 | 07:47 PM
hchan911's Avatar
hchan911
Send your car to Stephen (just wait til after he finishes mine). Why mess around?
As to price, you are going to spend $15k plus on this project. The P&Cs alone are more than $4k, and there's no reason to skimp on a full rebuild once you have it in pieces. This can quickly become an "as long as I'm in there doing this I might as well..." project.
-dc
Old 03-11-2005 | 12:13 AM
hchan911's Avatar
hchan911
Talking
Hi All ,
Well, Here the list of mods ( about 450fwhp ) that they sent it to me from Turbo Performance Center which included:
Sport cams
C2 turbo lightweight clutch
Fuel supplement kit
T36RS turbo
V-band
Scavenge pump
Bơost gauge
Profec bơost controller
GT2 head studs
Rod bolds
Valve spring & retainer kit
Valve guides
Stroker crank & rods
Port intake manifold
Port heads
Port injector blocks
Piston rings
Reman heads
Reman engine
Any thought . I appreciate all your comments
P.S: Sorry for a such long delay ( oversea )
Chan
Old 03-11-2005 | 12:58 AM
38D's Avatar
38D
Are you going EFI or staying with CIS?
Old 03-11-2005 | 01:48 AM
JBH's Avatar
JBH
I am a lttle confused by your last post Chan. It sounded like you were going to 3.4 P&C. The list you post above sounds like a rebuild with some work on the intake system - keeping the CIS intact. That's ok, but I thought you were headed a different direction.
Others can talk about the components, but I don't think this approach is going to get a reliable 450 rwhp
Old 03-11-2005 | 04:30 AM
hchan911's Avatar
hchan911
- Colin
GTC Motorsports
It's depend on EFI or 3.4conversion
From JBH
Jeffrey Harrison
JBH
I did requested them to send me 3 differences list of mods . That's just the first one I've received today (as you can see that i just posted ) and others 2 list of mods ( 3.4 conversion and EFI conversion ) haven't seen it yet. As long i have other two , i'll post it so you guys be able to help me .
1./ Which conversions is better ( What advantage and disadvantage among 3.3 vs 3.4 vs EFI )
2./ To tell they are being honest with me or not ?
And after had a bad experience with couple shops, only you guys that i can be trusted . Thanks
Chan
Old 03-11-2005 | 10:43 AM
38D's Avatar
38D
Unless your current P&Cs need to be replaced, there is no need to go 3.4. Just go EFI (Motec). Do the heads (port, polish, etc.), twin plug it, get a good exhaust, and do a K27HF.
Old 03-11-2005 | 12:46 PM
JBH's Avatar
JBH
I agree with Colin. By itself, a 3.4 conversion doesn't get you very far toward your goal. EFI with a new turbo and exhaust system ought to get you pretty close to what you seek.
What I still do not understand, is if you have to do an engine rebuild or you are just looking for more horsepower. To give you advice we need to know the current state of your motor. You also haven't said what you budget is for this project.
Did your shop quote a dollar amount for the work proposed?
Old 03-11-2005 | 12:55 PM
Earlierapex's Avatar
Earlierapex
HC,
If you do all the engine work without the EFI, you are going to run lean with CIS. If you go to EFI with the "relatively" stock engine, it isn't going to hold up over 500hp. If you want big horsepower, you have to do both.
You can get up to about 450hp fairly safely with CIS without doing a whole lot of engine work. If you want to take it in steps, do the engine work first and the EFI later.
I don't think it's really fair to say this is an either/or conversation as you really don't want to go all out on the EFI or on the engine without doing the other.
-dc
