Need help locating items in engine bay
I am planning on adjusting the CO myself this weekend and need some assistance from the experts. I am pretty sure I found the O2 sensor wire but just want to confirm. On the left hand side of the engine bay there are two wires that come up and make a connection. One has a barrel type connector and looks the same as the O2 connector on my '88 carrera. Is that the right one?
For the actual CO adjustment, I has these instructions from PorschePhD:
Does anyone have a picture of the area he is describing? I looked around last night but there isn't alot of room to play around in there. Can I get to it without removing anything?
Thanks for the help
Kerry
The adjustment is done from the top of the fuel head. Basically between the fuel head and plate behind the air box will be a stub that is coming out of the assembly. It is spring loaded. Inserting a 3 mm allen in to the stub then gently pushing down while turning the spring loaded stub will engage with the adjustment on the plate. A pinch of a turn will change the CO a lot so have a meter in the tail pipe. A 1/4 turn can change the CO almost 6 points. Sometimes more.
Thanks for the help
Kerry
You find it here, not much room, expect a little blood on your hands when your are done :-)
http://www.bentleypublishers.com/gal...=pc94&seqnum=9
