Electrical Precuations for welding
I need to use the welder to remove a few broken studs, what precautions should I take before I take the welder to the 964 turbo, was thinking
Disconnect Battery
Remove plugs from EZL unit, or should I remove the whole unit
Remove plugs to an ECU under the passenger seat
Any other precautions you guys think I should take.
Disconnect Battery
We always just disconnected the battery. But that climate control is super sensitive to even heavy jump boxes.
ABS, and alarm brain should be good.
Disconnect Battery
Disconnect Battery
peterpullin (01-29-2024)
I junk a lot of metal around that turbo and exhaust. save the case first.
