What to replace with engine out?
There are obviously some non-standard parts on the BTR 3.8, but since it's a 964 3.6 Turbo engine at heart, I figured this was the place to ask about what to replace while the motor is out.
The car ran great when disassembly started, but I figure there are jobs that are easy to do with it out that will be a lot harder to do once it's back in.
I'm definitely replacing:
In addition, I'm thinking of doing:
Is the boost pressure sender or boost pressure switch worth replacing now, or is it worth waiting until one fails since the intercooler is easy to access?
What am I forgetting? What would you add to (or subtract from) the list if it were your motor?
My shopping cart is already ridiculously full of gaskets and seals, so a few more won't hurt.
- Plugs
- Distributor cap
- Rotor
- Starter Motor
- Crankshaft Reference Sensor
- Oil Temperature Sensor
- Oil Pressure Sender
- Throttle body O-rings
Hello 965 friend,
here's what I did. See the link, I hope this helps
https://rennlist.com/forums/964-turb...-92-965-a.html
You must replace the injector blocks! and the coil. it could lead to frying your EZ69. Motor mounts,
Good luck
Helio
Good luck
Helio
Hello 965 friend,
Good luck
Helio
Good luck
Helio
Fritz
The basis of the motor is a bored out 3.6 Turbo from a 1994 965.
The intake manifold is a custom cast RUF part.
The fuel injection system is RUF modified but based on the 964 naturally aspirated motronic setup.
So.. no EZ69, and I think the injectors are unique.
heliolps2 (12-26-2023)
