720 hours, $80,000 in wholesale parts, this car doesn't stop kicking me in the nuts. 38k miles! Doesn't matter. Replace everything.
Anyone know of a Belt conversion and Belt size for A/c Delete? These A/c Clutches used to be $700. I'm not sure if there are conversions after market one available?
I think that you have removed A/C and want a shorter belt to skip the A/C pulley? Easy; you have to measure the linear length of the belt using a string, etc. Then you can cross it to the closest belt. Belts are labeled just like tires and the letters and numbers have a meaning. For example, Gates has a nomenclature that is ever slightly than Dayco, or Napa, etc.
I just went through this as I modified the engine on another car and I could rev 1000 rpm higher and kept throwing A/C belt. Any seasoned/grey haired guy at a respectable Napa store can cross the new length for you, since the other parameters are the same: IE) Width, V vs. Poly, etc.
No kidding. I found a old photo of where i locked the alternator to the fan pulley on a C2 turbo conversion. That's the easy way.
The difficult way would be to add a tensioner and use the ribbed belt. Rothsport, Clewett or Patrick.
For now the A/c is being pulled.
Uncle :-)
