Elephant Racing Introduces Bump Steer Reduction Tie Rods
Wow much cheaper and easier if it attains the same level of compliance that the RS uprights and RS tie rods achieve ...
Looks like a no brainier on my turbo which I already intended on replacing the uprights with at minimum the alum 993 pieces ..
Done the uprights on two cars and it's a considerable effort and not certain you could return it to even approx stock height without complete
reversal ..
Bert
reversal ..
Bert
heliolps2 (09-12-2021)
I've kicked around going to 993 uprights myself but I probably won't do it when I perform my suspension refresh next year.
that was back when I was entering into Preservation class. I'm done with that now, and onto Preparation.
so yea, per my post # 2 above, I would love to get rid of that bump steer feeling when pushing it hard @ high speeds on crappy roads
Hey Paul,... how did you end up (go, no-go?) with this Elephant bump steer kit?
Did you install it? ... Have you driven it to compare??
.... I'm still very interested in your evaluation
No haven't really done anything to my suspension and won't for another year.
I was looking at the chart Elephant has on their web site that purports to show the improvement with those end. I have to call them as it doesn't make a lot of sense.
also contemplating the Evergreen Turbo "Raptor" upgrade....
Brandon
'91 Turbo
I'm not 100% - but from what I understand Charlie takes your OE 7200 turbo and replaces internals - I _think_ both impeller and compressor wheels with CNC parts (although maybe just the impeller side?) - so a lighter assembly - plus I'm guessing modernized fin shapes? so that it spools a few hundred rpm faster and makes more power (10%?) across the range. All without having to deal with a domino effect of other changes because it is still your stock turbo housing. Turbokraft speaks highly of it - as does RarlyL8. Charlie says at sea level boost by 2400 - full boost by 3100. Not sure what stock would be as I have to deal with more lag here at 5200+ ft (often more). Evergreen charges $1175. There's thread on Pelican that also talks about it. I mostly like that it's a reasonable price for some power that doesn't involve swapping out other parts etc. I am curious, however, if the WUR would need to be tweaked - me thinks decent chance no.
EDIT - here's the thread - couple years old but some good info in it
http://forums.pelicanparts.com/911-9...-help-k27.html
Brandon
'91 Turbo
Brandon
'91 Turbo
Did anyone pull the trigger on the bump steer kit from Elephant ? Would it make a difference to the average driver ?
it also looks like they supply the inner tie rods so in the end it looks a bit cheaper than new OE parts
i have an RoW car which is lower by default.
thanks!
thanks!
