Boost Gauge
Hi everyone,
The turbo boost readout on my tach is stuck at 0.7
The gauge was recently cleaned and given a new lens at PA Speedometer and then re-installed. I have ruled out the possibility that PA Speedo did anything b/c it was just a new lens and a cleaning.
Any ideas?
Thanks!
Any ideas?
Thanks!
are you sure the wire at the intercooler are in right place?
if there is wrong readout it often ends there...
ianbsears (05-14-2021)
Thanks for the ideas. You were both right. It was the boost pressure sending unit on the intercooler. The wires were on but the unit had failed. When the wires were removed the readout fell to 0 and when reconnected went straight back to 0.7. New one is on order!
ianbsears (05-15-2021)
the staulk on your steering wheel column (left side). pull it back towards you to change the various views
Lol,... for 17 yrs now, my wife & I are constantly changing it back & forth ... she likes to see MPH,... I like to see the boost level ... we joke about it all the time
ianbsears (05-19-2021)
With my Innovate PSB-1, I leave it set to peak boost so I can review it safely at a stoplight.
Convert your clock into a manual boost gauge which allows you to monitor both boost and vacuum levels. The right dial starting 1:13 is what I put in my 3TT.
https://youtu.be/hOVxN6Jb1j0
Helio
heliolps2 (05-20-2021)
great! where did you source the dial? hava a spare clock for this and never started ...
