What suspension do I have?
It appears obvious that I have H&R springs. But what are the struts? Does this H&R setup come as a set? If so, what are the spring rates and who makes the struts? Are the struts/shocks revalvable (a la Bilstein?) What do stock struts look like (are these stock?)?
Front:
Rear:
Rear closeup:
Front:
![](http://homepage.mac.com/jupeman/.Pictures/suspension/frontstrut.jpg)
Rear:
![](http://homepage.mac.com/jupeman/.Pictures/suspension/rearstrut2.jpg)
Rear closeup:
![](http://homepage.mac.com/jupeman/.Pictures/suspension/rearstrut1.jpg)
It's hard to tell by the pictures but it appears to be stock shocks and struts with H&R springs used to lower the car.
I don't think they can be revalved or that it would be worth trying.
From the looks of it they appear to have been in the car for a while.
Newer better technology out there now. For track use you probably will want to upgrade.
Ok, I wasn't sure what stock struts looked like on this car. There is better technology out there, but I'm not sure I want to pay for it. Although adjustable shocks are all the rage today, I'm not sure I would make use of their adjustability. Further, mounting the remote reservoirs start to require modifications to mount them (particularly in the rear). Thus I am leaning toward "old tech" Bilstein HD or RSR struts/shocks revalved to match the spring rates I want (600-800 lbs range). Because I want spring rates like that, systems like the PSS9 don't work for me (too light).
