964 Turbo Forum 1989-1994
Fuel Injector - clean or replace
Old 12-02-2022 | 09:23 PM
  #31
Nyx's Avatar
Nyx
Originally Posted by ianbsears
Paul,
It does sound like Bosch injectors are fine vs Porsche (since maybe they are one in the same??).
Ian
Exact same part number.
62702
931 110 225 00
$40.89 USD
rock auto
ianbsears (12-02-2022)
Old 12-03-2022 | 12:27 AM
  #32
Metal Guru's Avatar
Metal Guru
Ian, first your shop says the new injectors are the problem, then they say maybe we should install the new injectors. Sorry, but they wouldn't inspire me with confidence.
I'm beginning to wonder if many shops are up on the operations of CIS. The guys who own longnose 911 with mechanical fuel injection have it worse. At the bottom of the heap are the owners who need their Carrera 4 engines worked on as many of the mechanics trained on those powerplants are deceased.
Old 12-03-2022 | 05:28 AM
  #33
997 tt/rs's Avatar
997 tt/rs
Guys, my friend's 964 turbo had a problem when starting on a hot engine, it only fired with the gas pressed to the floor. Colleagues from the forum suggested to replace the fuel accumulator for which I am grateful to them. After replacement, the problem disappeared. A hot engine starts normally every time without touching the accelerator. As for the fuel injections from bosch, they are the same injectors that are expensive at Porsche, bosch makes them for porsche. Exactly the same story with the fuel accumulator
ianbsears (12-05-2022)
Old 12-03-2022 | 04:58 PM
  #34
wicks's Avatar
wicks
Yes have done accumulator to solve problem on a couple of my cars, but the 73 is MFI...has new fuel pump, redone MFI pump, new filter, new injectors, new hoses (all of em)...
Old 12-05-2022 | 02:00 PM
  #35
ianbsears's Avatar
ianbsears
@Metal Guru actually this is when I was switching shops. The "replace the injectors was the local Porsche dealership" who frankly liked to replace lots of things The shop I was referring to is the new shop which still gets an A+ by me. But yes, I agree the institutional knowledge is not supported by demography which is why when you find a reputable shop....... Hopefully as this journey progresses I will accumulate enough knowledge myself to be more than a little bit dangerous.
Old 12-05-2022 | 02:18 PM
  #36
peterpullin's Avatar
peterpullin
this old cis cars are tricky. they create new faults occasionally.
tried to balance my injectors (new 2500 km) as a test only. wanted to find out if volume changed from new to this distance. all tests fine, little too much fuel over all so i started to correct this. was late and i started over next day and lost complete fuel pressure. once i stopped the pumps it dropped to zeeo in seconds.
i went through the whole way: accumulator, wur, fuel head, pumps, etc. ! Adays of research for nothing. one day test ended with full pressure.
i still do not know why or what happened.
it works again.
Old 12-05-2022 | 08:45 PM
  #37
Metal Guru's Avatar
Metal Guru
Originally Posted by peterpullin
I still do not know why or what happened.
it works again.
The ghost in the machine.
"Demons be gone!".
peterpullin (12-07-2022)
Old 12-07-2022 | 11:05 AM
  #38
997 tt/rs's Avatar
997 tt/rs
Guys, situation in the fuel tank should be also checked 😳
Old 12-07-2022 | 01:16 PM
  #39
Metal Guru's Avatar
Metal Guru
Looks like it's time to pull your tank, remove the screen on the pickup and flush it out.
Old 12-07-2022 | 02:04 PM
  #40
ianbsears's Avatar
ianbsears
@997 tt/rs Sorry for the amateur question but what are we looking at?
Old 12-07-2022 | 02:36 PM
  #41
997 tt/rs's Avatar
997 tt/rs
It's fuel level sensor.
my fuel tank is like new 😊
ianbsears (12-08-2022)
Old 12-07-2022 | 02:37 PM
  #42
997 tt/rs's Avatar
997 tt/rs
And this...
Old 12-07-2022 | 04:12 PM
  #43
fritz k.'s Avatar
fritz k.
We pulled the tank sender on a 930 MY 1980 recently, probably for the first time ever. No water, no dirt, no deposits, no nothing. Just like new.
Fritz
Old 12-09-2022 | 01:36 AM
  #44
fabricar el 965's Avatar
fabricar el 965
Good news, they clean up nice 12-08-22 Dunavant Build. Replace and move forward.
ianbsears (12-09-2022)
Old 05-08-2023 | 08:20 PM
  #45
911 2's Avatar
911 2
Where is the screen located as in the pic above, can it be cleaned or best to replace
Quick Reply: Fuel Injector - clean or replace
