Air pump function
Air pump function
Hi there
Here's what I understand, The air pump injects air into the exhaust ports on cold starts for emissions, after the engine is warm it no longer injects air into the ports. The air is diverted using the two diverts into the stock cat or Fabspeed bypass that I have on my 965 or the atmosphere with after market exhaust if it's done correctly. The only thing that robs power is the belt driven air pump.
Once the air pump belt is removed but all the air lines stay, What the purpose of the Stock Jectronic ECU and oxygen sensor now ? I have some ideas, but i'm looking to see if some has a more educated answer
Hi there
