clutch nylon bushings part no please
decided to do the roll pin and clutch bushes on my 964 turbo pedal assembly so ordered the bits
i received a roll pin part no N0233511 the bushings I received were metal, part no 99992408000, should the clutch pedal bushings not be plastic if so what is the part no for these and what have i been sent
We all like pictures , so when ever possible post some.
Thank you
Thank you
struggling to put up pics
the metal bushes I received, one inserts into the main body of the pedal assembly where the clutch pedal assembly starts and the large hollow tube slides into and the second metal bush is inserted into the end of the hollow tube,these really dont seem worn and are pressed in i dont know if its worth replacing them.
The pins was cracked in three places but was still intact so i donnt think a new pin is going to improve my shifting
when i reassemble should i be using grease on all the joints
would be easier with pics
