1991 ABS and tires sizes?
My 1991 now has a set of 18" RH wheels.
We also installed big reds up front.
Noticed that the fronts wheels will lock up under hard braking.
Would the ABS in the 1991 be sensitive to tire diameter or big red upgrade?
I'm no expert but I sure would be surprised. Really I don't see how it would know...it's just comparing rotating speed of each wheel, no?
Brandon
'91 911 Turbo
'00 Audi S4 highly mod'd DD
Brandon
'91 911 Turbo
Strange. Got same setup, big reds, 18s 235s front tyres, either Tropheos, Cup back in the days or Cup2s and I dont lock... Crap ABS but not locking. smthg's wrong
Factory called for 255/35/18's
I installed 285/35/18's and it triggered my ABS light, I cleaned all my sensors and replaced relays, nothing fixed it, I went back the Factory size tire and the ABS light was gone.
Contamination and corrosion of the caliper pistons or collapsing rubber lines are also a possible cause. They act as inadvertent bias valves. The brake fluid pressure will achieve equilibrium so when it can't flow to the rears any more it will increase flow to the front.
Thank you for the update
The ABS computer for the C2 and turbos are all the same. Changing tire size shouldn't impact it unless you mess with rolling dia.
