How much HP gain ?
How much HP gain ?
Do any one know how much HP will our 3.3 turbo's gain at 1 bar boost and no cat .
Stock 92 turbo is 320 HP. does anyone have dyno tests ?
I suggest you at a minimum inspect the diaphragm on your wastegate and have the car dyno tuned if you make this change. You can see boost creep and if you exceed 1.2 bar I believe is the point where the fuel pumps cut out. Not fun.
If you want more sound it is fun to gut the WG cat the car roars at WOT.
I did have a little boost creep as you said, I turned the boost sense I have a manual boost valve located in the engine compartment nicely tucked under the intercooler, I was also told that running to much boost can harm the EZ 69 ICU, I don't how of that is true....
In the past in my old 3.3 turbo i did blow my WUR diaphragm running 1.2 bar boost, But I was doing alot of DE's and autocross. I had Larry from CIS install a heavier diaphragm. But now I don't drive this car that hard, Maybe W.O.T for a few seconds at best. Once the WUR needs rebuilding I will send it Brian,
Brian is a great guy, I stopped by his home back in 2012.
Would I use a drill ? and what kind of drill bit would I use ? Or would chisel it out with a hammer ? I would have a vacuum sucking the stuff out while drill. Good Idea ? your thoughts please
My old 3.3 turbo had a straight pipe on the WG, It sounded great. Whats the best way to gut tha WG cat, I was thinking of gutting while it attached to the car, After removing the tail pipe of course.
Does anyone have a WG Cat they want to sell or give away ?
You Need Fuel, Get Euro Fuel Lines & Injectors, Might be Hard to Get, Then You can Go 1.1-1.2 Bar.
I Know, Trust Me I Made Huge Power On a CIS 92, & I was Told Those 2 Items were not a Factor, WRONG, Was getting Lean at 4700, Put them in & Made Music.... Huge Improvement !!
I Had Every Thing You Can Possible Done To a Stock Motor & A Garrett GTR35 Turbo.
On a stock engine anything over 1 bar even with new injectors or fuel lines can be disastrous. I have seen countless people try this and only ended up with their heads lifting. I hate to say it but CIS is limited and the numbers you posted are just not possible unless you go with a better injection system and stand alone ecu.
The maximum you can safely run on CIS without some type of modified fuel head (which doesn't exist) on a 3.3 is 350 to the wheels. Anything over that takes a lot of effort and expense. You just can't flow enough fuel through a CIS head to make these kind of numbers irrespective of fuel line size or injectors. They also claim a 25% drivetrain loss which is ludicrous would put you at 550 BHP and nearly 625 ft pounds of torque at the engine. I hate to say it it just isn't happening on CIS.
I Get It, Nobody believed Me, But It's Real & Only 15psi, It was the Garrett turbo that spooled so fast that did it, It would just take Fuel fast.
Like I Said Everything was done, 2 fuel pumps, warm up regular & Fuel head both done 3 Times, Headers, No Cat, air Intake, Etc, We kept running out of Fuel, Dawes MS Helped Me, Everyone from coast to coast was called, Fuel Lines & Injectors did it, I spent 2 Years on this car I'm Certain, I used to work with Andial before they Closed, I've done a Lot of builds, This car kept up with my Modded 993tt, Lambos, Very Fast & Shot Huge Fireballs, I'm still trying to buy it Back...
Not gonna go into the Dyno Sheet, Or Debate the Power, That wasn't My Point, If You do those 2 things It will help the fuel to 6500, That's my point, I Think The Injectors ended in 0111(not sure), They Are NOT 3.6 Injectors for Sure, Every Car I Knew of Ran Lean at 5000-5500.
I Sold a Car to a Guy That has a Andial 930 CIS Made 465 Crank.
