Broken Diff Cover Stud
Ok, I messed up. I was removing all the engine cover mounts from the car as I don't intend on using an engine cover, I kept hitting my head on them working under the car, and they looked like they could easily get snagged on something.
Well, after removing the one on the diff cover I lazily Google'd the torque spec for the nuts and quickly found 33ft/lbs. WRONG. It's 17 ft/lbs, and somewhere between the two, the dreaded SNAP. I could've cried. I did curse. Loudly.
Anyway, it's bleeding fluid now so I have to attack this ASAP. Couple questions for anyone that has done this.
It looks easy enough to do in the car (I have a 2 post lift.) Steps as I see them:
- Drain the fluid.
- Pull the axle.
- Remove diff cover nuts, diff cover.
- Replace stud.
- Reassemble with new o-ring (and a new shaft seal because Im already in there.)
- Refill trans fluid.
So am I missing anything? Is there any reason I can't do this as described? Of course, I've read the service manual and gotten all the proper torque specs this time around.
Any advice would be great.
Thanks in advance and wish me luck!
- Drain the fluid.
- Pull the axle.
- Replace stud.
At least you didn't misread the torque spec for the bolt that bolt the axleflange to the differential guts like I did lol. Sounds like a good plan. Rebuild the limited slip while you are in there if you have one. It's simple. When taking that cover off I remember that you need to take a stud out to remove it. I forget which one but I think it in the right upper corner when you look at it from the wheel well.
Ah good to know. Didn't see that in the service manual.
I wish I had an LSD. I seriously considered buying one and using this as an excuse, but after a 20k motor build, I really just want to enjoy the car without writing any 5 figure checks for a bit. That begs the question though, can you get the diff out with the trans in the car?
Which reminds me I need to have BBI get a quote from you on a diff for my 964. Motor trans coming out for rear cage build, flywheel, and bunch of "bits".
Contemplated the regear, going to hold until I get the motor direction sorted. I like 3rd, 2 is too short.
I've the factory LSD it now....
